I will take a look as I do a code review, but somehow you’re the only one who has had issues, maybe you need to use a TOR bridge? Looking at the logs only one slatepack failed to decrypt, you might have been the unlucky one also. Before submitting them make sure there are no leading or trailing whitespaces in it. I use Debian with GNOME desktop and the copy and finalize functions were working just fine on my end. I don’t have a Windows or Mac computer to test anything else unfortunately.
I Write a Telegram Bot with faucet and donate function. Username: @grin_mw_bot
the bot is available in the following channels:
You can use the bot as follows.
Ways to donate:
- Send plain Slatepack (send)
- Send Slatepack file (ends with .S1.slatepack)
- Tor
Ways to use faucet:
- Send plain Slatepack (receive)
- Send Slatepack file (ends with .I1.slatepack) away.
THANK YOU! This takes some pressure off of me, I haven’t been monitoring my faucet since I have been so busy lately.
I tried the faucet with an invoice for 1ツ and it worked! It’s not the most intuitive and could use better instructions TBH. Now I’ll donate it back, I see there is a limit of 2ツ per user per day, I hope there is no workaround for this. Believe me, people will try and abuse it any way they can.
Bringing the site back up in the morning and will load 100ツ in to the faucet, I wouldn’t mind if traffic dropped off a bit due to recent downtime.
EDIT: I am so fucking tired today, I’ll do my best to get around to the servers tonight (fuck MS).
I have improved the functionality of the mainnet faucet to make it more fair for everyone. It no longer penalizes you for trying the faucet when it is empty, or when you are rate limited. I had overlooked that in both these instances you were then rate limited for 24 hours from that point. I’ve also stopped letting the public know when the faucet is replenished as 100ツ would only last as long as it took for 10 UTXOs to hit 10 confirmations basically.
