Another Cuckatoo bounty succesfully claimed
As reported on the Cuckatoo project page [1], Stephan Theisgen has won $10k by fulfilling the requirements of the Linear Time-Memory Trade-Off Bounty.
I include the full text of that section here:
$10000 for an open source implementation that uses at most N/k bits while finding 42-cycles up to 10 k times slower, for any k>=2.
All of these bounties require n ranging over {27,29,31} and #threads ranging over {1,2,4,8}, and further assume a high-end Intel Core i7 or Xeon and recent gcc compiler with regular flags as in my Makefile.
On April 11, 2025 I received a submission from Stephan Theisgen to claim this bounty, providing me with access to his splean github repo. This contains not only the required implementation, but also an extremely detailed write-up of the task, Dave Andersen’s sampling suggestion, the solution approach, pseudo code for all the steps involved, an analysis of the amount of number of hashes to be computed, parameter selection, memory requirements and of various data structure candidates and their selection, code testing, and validation. And it came with over a dozen references. A wortwhile submission to the Journal of PoW Algorithms, if there were such a publication.
The code quality matched that of the documentation. After finally gaining access to a high-end Linux box, and with Stephan’s help in using the appropriate compile-time defines for my desired benching runs, I was able to verify the claimed performance.
My estimate of memory deficient solvers incurring “at least one order of magnitude extra slowdown” turned out to be overly pessimistic. It looks to be closer to half an order of magnitude for this well optimized solver.
What does this mean for the feasibility of small memory ASICs? As Stephan’s analysis showed, a “tiny” ASIC with only N/k bits of memory needs to hash each edge roughly (k+1000) times to find the cycle in a graph containing one, while the lean miner needs to hash each edge less than 6 times. That will make the tiny ASIC use far more electricity per solution, quickly wiping out the cost benefit of using negligible memory. Cuckatoo Cycle thus remains a “Proof of SRAM”.
Congratulations to Stephan for winning the bounty, paid out on April 30.
[1] GitHub - tromp/cuckoo: a memory-bound graph-theoretic proof-of-work system
Amazing! A treat to behold. What is the best way this is to help Grin?
For peeps who didn’t get it what this means basically:
The bounty asked:
What if someone tries to cheat and mine using a chip with way less memory? Can they still be competitive?
And Stephan’s answer (by building it and testing it) was:
Yes, they can mine, but they’ll be so much slower and waste so much energy that it’s not worth it.
Bottom line:
• The G1 Mini is safe—this bounty reinforces that its SRAM design is still needed.
• The test shows: Cuckatoo Cycle really does force you to use fast memory if you want to mine efficiently.
• So the algorithm still delivers on its goal: memory-hardness = decentralization-friendly mining.
Didn’t understand the technical details, but @tromp who is a man who kept his word, paid the bounty :raised_fist:
