SuperGrin - GUI Wallet [Mainnet] v1.0.2
Hi All,
After a few days working on it, I think I can finally release what I have been working on. This should be a GUI Wallet we have been waiting for, Simple Wallet with file based transaction allow you to send and receive Grin Coin.
This app currently only run on Mac, will add the windows release in the coming days.
It’s currently running on Floonet Chain for GRIN. If there is no problem in my testing, I will try release the Mainnet chain build Tomorrow or In 48 hours from now.
and Yes, It will be open sourced the day I release the Mainnet Chain build.
Here is the mainnet release.
Introducing SuperGrin Mac App:
Source Code:
Download link:
How to install:
  1. Download the binary from the github.
  2. Extract and Copy the SuperGrin App to Applications Folder.
  3. Double-Click the shiny SuperGrin Logo.
How to use it should be pretty straight forward.
Every file that Finalize and Response will be generated to Your Desktop.
Feel free to check the code, to check whether its legit or not. All source code available on Github.
I greatly appreciated any amount to support my work in the future,
Please send http based transaction to,
http://35.197.132.97:3415
Any feedback and support, please write on this thread, I try to help as much as possible.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
I have downloaded the app and all is great so far.
A few questions:
• Is it ok to rename the output files once on the desktop?
• After slate files have been finalizing should they be deleted from computer?
• Is it ok to have multiple transactions or is one at a time?
I will check back for when it’s ready and on main net. I am ready to receive now.
• Do I need to generate new keys or download again when live?
14%20PM
  • Yes. you can rename and change the name to anything.
  • Nice one, I think I can make that happen.
  • You cannot create multiple transaction before it’s finalized by the network. thats why all the balance will be locked in "Awaiting Confirmation state. I think this is the basic of Grin transaction. I try to read more about this.
  • Yes, you need to create the new keys, since the wallet _seed.key will be different for the mainnet
Thanks
Mainnet wallet release
Please download here,
https://github.com/rheza/SuperGrin/releases
Great I have the new release downloaded and created new wallet.
I have a recieve.input file that I have drag and dropped into the SuperGrin app but I don’t get anything happening. I see the green plus sign before letting go but nothing confirms the file yet. Any suggestions? Perhaps I didn’t fully delete the test wallet?
Sorry,
I still have some of my floonet code on the production,
This should be fixed on the next release.
Release note:
bug fixes release.
  • Ask password when user want to send or receive the coin.
  • save password to local, so it will not ask as much.
  • Please use check balance button, if you think it’s not responsive.
Please replace the old version with this.
Any news about the windows release?
Still working on it though, I think i need to use a workaround for the windows, Like a Automatic password generator. Have you try the Mac version ?
Thanks
Bumped version to 1.0.2
I wish i can.
Sadly, am a windows user :frowning:
@futurerheza I downloaded Supergrin and got it working ok, received a deposit from a mining pool via file, have it in supergrin now but when I went to create a transfer out it got stuck after my password. It always now reflects my balance as 0 except occasionally when I hit check balance it will update (but not always). Like today it reflects as zero and won’t update.
Any suggestions?
most Excellent looking forward to a good windows version !
Still missing my 30 grin from this wallet, at this point hoping it just wasn’t stolen by it. But can’t get a response now and going on 10 days.
Would be cautious using this software.
no, it wasn’t stolen sorry, Have you save your restore seed ?, you should be able to restore it on grin wallet official, and sent it out from there.
I will take down this wallet for the time being.
I do have the seed, let me know if you need any info on what happened. I’ll import the seed now, Thanks for the reply!
Man this is the thing I was looking for, thanks!
