I just started mining Grin, but keep getting Stratum Connect #143# no such host is known. my GPU is RX580. please help, Thanks
“This is John Conner, thanks for accidentally killing Skynet that time you tried to mine grin in 2019. Cheers.”
didn’t quite understand what it means slight_smile:
which host you are trying to connet? probably the miner is right
@Miner021619 It’s an out of left field joke referencing the movie ‘the terminator.’ Skynet was the AI that took over the world, and started enslaving man kind. My joke was that, in all your troubles getting the mining going right, you accidentally did something in the terminal that set into motion the end of skynet, therefore saving mankind from being enslaved by a rogue AI. Thanks!
