this simple formula MW, which is somewhere in the Euclidean algorithms, is only described differently, I’m sure that if you look for it there is.
MW
(k+j)*H = k*H + j*H
But Euclidean has gone further than you, with hundreds of combinations of formulas
1071 = 2 × 462 + 147 | 1071 - 462 - 462 = 147
462 = 3 × 147 + 21 | 462 - 147 - 147 - 147 = 21 a number less than 147 or, Yes
147 = 7 × 21 + 0 | 147 - 21 * 7 = 0
answer
1071 > 462 > 147 > 21
so by studying Euclidean algorithms you can come up with a more advanced version of grin
and I do not recommend telling you that you have come up with unique algorithms, because it is not so, you just do what has long been invented.
So it is better to study the work of Euclidean than to break your head once again
I also believe that your license may be partially invalid because the algorithms are not yours. And if someone starts digging, it’s a violation of rights.
