Hi
I have installed Grin++
i can type in the slatepack, but copy paste does not work. I used copy / paste in this message and it works.
my status is running and the address green.
Any idea?
Txs
Hi
Any idea?
Txs
Probably your problem is with slatepack paste. Use middle key on keyboard touchpad if you use laptop. If you use linux try ctrl+v ctrl+shift+v or alt+shift+v or configure paste command.
Thanks for the reply.
I am on my desktop computer, running windows 10. 64 bit.
Nothing works. I reinstalled but same result. Copy paste is not working, Any other ideas?
Thank you
Yes try Cntrl + v to paste and for copy you have button
Ctrl+C (copy) and Ctrl+V (paste) are common keys in windows. Did you try?
Hi. I tried last few days with also these commands. Today it worked with Ctrl+V.
Thanks for the help
